boost help
Old Apr 15, 2010 | 02:00 AM
black smoke77's Avatar
Default boost help
hi i have an 01 7.3 f250 with my tony chip turned all the way up is 27lbs of boost ok to be running my truck at? i have a few more questions too is the fluid for the the rear diff the same as the front? and is the wicked wheel worth putting on my truck? and wheres the best place to put my egt probe? also i wanted to say at alot of the post i looked at on here your really good at helping ppl figure out what they need with answers and stuff and the pics u supply with the deatail are very good also will the 2007 f250 front end bolt right up too my truck????? thanks for your help
Old Apr 15, 2010 | 01:12 PM
stephenjr's Avatar
yes my stock is at 28lbs runs great make sure you get the boost anahlator from beans, your ecu defuels after 23 lbs. no good slows your down
Also yes same fluid, wicked wheel is ok you get more of a whistle and almost no surge/flutter, egt probe i put mine where it was the easyest to to reach driverside just remove the shock and its right ini front, just use lots of grease and whip and grease whip and grease you dont want shavings in the motor
Old Apr 15, 2010 | 07:23 PM
thanks you would happen to have a pic of your egt installed? also what part of jersey are you from? u going to the swapmeet this this weekend at english towns raceway park? and are u sure my ecu will defuel after 23 i have a tony wildman chip installed on my truck
Old Apr 15, 2010 | 07:48 PM
stephenjr's Avatar
I do not have a pic sorry I could send one to your celly email me at civictyperturbo@aol.com Im from middlesex central area englishtown is 20 min away. I dont go to the swap meets nothing i really need. Now the ecu defueling the only real way is when you floor it and boost over 22-23lbs do you get a check engine light? if so its defueling. if not the chip covered it. I dont have a tony chip But i hear good things about it
Old Apr 15, 2010 | 07:55 PM
CSIPSD's Avatar
Drivers side manifold, from the bottom.
Drill, Tap and install. No grease unless you live somewhere that gravity is not in effect. What little shavings might defy gravity and fall up will blow right past the exhaust wheel and out the tail pipe.
Yes, the PCM will defuel the truck without some kind of boost fooler or regulator installed. Some trucks its at 22 some its at 24, every one is differant.
Old Apr 15, 2010 | 07:56 PM
CSIPSD's Avatar
And welcome to the site!!!
Old Apr 15, 2010 | 09:05 PM
thanks guys also csipsd i got the the strap with my egt probe can i use that? looks like a hose clamp with the threaded fitting on it thanks
Old Apr 15, 2010 | 09:27 PM
CSIPSD's Avatar
Yes you can... Same process, Drill and install...
Old Apr 15, 2010 | 09:49 PM
is there any real modifications to put the 2007 front end on my 2001? and will the wheels fit too?? thanks
Old Apr 15, 2010 | 10:05 PM
CSIPSD's Avatar
The 2007 front end is a bolt on deal... The wheels I believe have a differant offset, but I cant recall for sure.
