oil pressure went goofy
Old Apr 14, 2010 | 06:56 PM
lunk's Avatar
Default oil pressure went goofy
my oil pressure gauge went to 0 then every now and again it will read normal. i got P0523 code (engine oil pressure sensor switch high voltage) im assuming sensor needs to be replaced? how hard is that?
also a code P1693 (turbo charge controll circuit malfuntion) how seriuos is that.
this how they showed up P 0523
P ECU
P 1693
its a 2001 dodge cummins any insight would be great
Old Apr 14, 2010 | 07:46 PM
12vcummins96's Avatar
the turbo code dont fret the oil sending unit needs to be replaced it easy to replace
Old Apr 15, 2010 | 08:56 AM
lunk's Avatar
cool thanks a bunch
Old Apr 15, 2010 | 09:09 AM
Diesel Nut's Avatar
P1693 is just a companion code meaning that a code has been set in the one of the 2 computers. Its a very common code to find and really means nothing. Take a look at your wiring for the sender and make sure its not damaged and if not, then replace the sender.
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
