Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Bio Diesel-2008 Dodge Ram 2500?
Old Apr 10, 2010 | 11:35 AM
jck1978's Avatar
Default Bio Diesel-2008 Dodge Ram 2500?
I own a 2008 Dodge Ram with a 6.7 cummins. I live in Oregon and have a few places here that are selling B20 and B99. Is Bio Dieseld safe for me to run in my truck? I would really like to run it! Will my local Dodge dealer know I am using it if for some reason I need to take it in to have something fixed. My truck is still under warranty still. Thanks
Old Apr 10, 2010 | 03:16 PM
5.9Bronco...eventually's Avatar
Dodge actually cant do anything to your warranty if you run a B20 or lower blend. Check out biodiesel.org for more info on anything biodiesel. Dodge warranties B20 and lower blends on anything after a model year 2002.
Old Apr 10, 2010 | 03:44 PM
mikmaze's Avatar
just keep a spare filter with you, I can't imagine on an 08 truck having much crud in the tank yet, but if it is there the bio will break it up and you could plug a filter quick. I ran a tank last tank of 10% and noticed a smoother running motor.
Old Apr 13, 2010 | 03:00 PM
06Dodge's Avatar
Dodge only approves B-5, B-20 is only approved for Commercial/Fleet and Military use as they are set up to take care of/better handle the water content in Bio, this is what I have been told by 2 Dodge dealers. If you get caught with B20 under warranty I hope you are at a dealer who does not care if its B5 or B20 as some look at it as away to make $$$$$$.
Old Apr 13, 2010 | 04:03 PM
Cummins B20 B20 Approval is for 2002 and later emissions-compliant On-Highway ISX, ISM, ISL, ISC and ISB engines. B20 is also approved for Off-Highway engines including: QSX, QSM, QSL, QSC, QSB6.7, QSB4.5, QSM Marine, QSM G-Drive. All 2010 Cummins engines will be B20 compliant.
This came directly from the national biodiesel board. They are the "gods" of biodiesel and everything related to it.
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
