WILL NOT KEEP RUNNING ?
Old Apr 10, 2010 | 03:49 AM
MUSCLE1's Avatar
Default WILL NOT KEEP RUNNING ?
04.5 WITH 72000 MILES ON IT JUST STOP RUNNING FEELS LIKE IT OUT OF FULE? STARTS UP RUNS 3-7 SEC AND STOP? QUITS WHEN I STEP ON IT IT DID THIS AROUND 5 TIMES NOW IT WILL NOT START ?IS THIS THE LIFT PUMP? IF SO DO I LET THEM PUT ONE IN THE TANK ? ANY HELP WOULD BE GREAT THANKS PS I JUST FILED UP HAVE A FULL TANK IT IS STILL COVER UNDER WARRANTY IT WAS APER OWNED I HAD ASMARTY ON IT FOR 2 WEEKS I NEVER STEP ON IT NO NOT ONE TIME 1/2 WAY AT MOST WAS GETTING 18 MPG AND NOW WILL NOT RUN? WILL PUT IT BACK TO STOCK FOR NOW THANKS FOR ANY HELP SORRY FOR THE CAPS I AM NOT YELLING JUST BUMOUT NO TRUCK check with smarty it was code p0628 low volt lift pump?? now dodge said it not coverd?? any help thanks
Last edited by MUSCLE1; Apr 10, 2010 at 03:22 PM. Reason: check code with smarty it was po628
Old Apr 10, 2010 | 06:58 AM
12vcummins96's Avatar
sounds like the lift pump but check fuses do you have any codes ect
Old Apr 10, 2010 | 07:37 AM
dieseldude03's Avatar
x2 lift pump.
That is actually one nice thing about these 3rd gen Dodges vs. the 2nd gens. The lift pump goes and the truck just quits. Yeah it sucks being stranded, but a tow bill is a hell of a lot cheaper than a new injection pump!
Old Apr 12, 2010 | 08:55 PM
MUSCLE1's Avatar
I order a air dog ll 100 I can use stock pick up and return to fill tube and it ajustable and should work up to around 500 to 600 hp the teck said he has seen it work past 650+hp? i will be lucky to see 500hp some day i hope i was going to use A raptor and filter heads but it would have cost just as much or more but no air seperator but could have used meny diffrent filters caT BALDWIN FLEETGUARD EXT. O WELL GO WITH THE KIT WILL KEEP STOCK FILTER ALSO FOR NOW
ssmith.77
Nov 25, 2018 06:56 AM
ROCKITV8
Jun 17, 2015 08:38 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
CumminsAtYa
Mar 17, 2015 09:23 AM
carid
Jan 12, 2015 04:32 AM
