factory specs? 95 K2500 8Lug chevy
Old Apr 9, 2010 | 09:07 PM
superburban4x4's Avatar
Default factory specs? 95 K2500 8Lug chevy
What is the factory specs for ordering aftermarket wheels for a 1995 Chevy K2500 8lug Suburban 4x4 ...ie..8x165.1, 8x170 does anyone know for sure? Thanks
also i have only found one suspension lift for this truck? why is it that the 8lug is hard to get a suspension kit for? Or am i just not lookin in the right places?
Last edited by superburban4x4; Apr 9, 2010 at 09:07 PM. Reason: Automerged Doublepost
Old Apr 9, 2010 | 09:51 PM
94duality's Avatar
your suburban should have the same suspension as a pickup, so finding them should not be that hard (i havent looked to be honest). the hardest part might be for finding one for a diesel
Old Apr 9, 2010 | 10:56 PM
Default lift kit
it seems that all the kits for trucks are for 6lug only it usually states that this kit will not work on 8lug trucks...and mine is 8lug...
Old Apr 10, 2010 | 12:02 AM
FastCR's Avatar
8x6.5 is your lug pattern. 14mm studs IIRC.
Pro comp, BDS, etc make a lift for it. It's the same as the k2500 pickup.
Old Apr 10, 2010 | 11:21 AM
tltruckparts's Avatar
correct. as for the reason why the lift wont work from a 1/2 ton truck. the upper control arms are 12" apart on a half ton, theyre 14" apart on the 2500 and up. therefore they use different control arms so the lift makes it different
Old Apr 11, 2010 | 08:05 PM
Default lift kit
i have a 93 2500 with a 350 gas engine and 6lug wheels and the lift kit for it will not work on my 95 2500 suburban so its not just a 1500 to a 2500 difference...it has something to do with 6lug and 8lug but i dont know why the lug would even matter at all.
Oct 16, 2014 07:10 PM
