98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
hub replacement on a 99 2500 4x4
Old Mar 29, 2010 | 12:19 PM
biged681985's Avatar
Default hub replacement on a 99 2500 4x4
i replaced the hub on my front passenger side of my truck. i took some :pic: and figured i would do a short DIY on it. it is a 99 dodge ram 2500 4x4.
started off my jacking the truck up, and grabbing the wheel and shaking it
next you take the wheel off
next is the brake caliper to remove. i take a couple zip ties and tie the caliper to the frame to keep it out of the way
next take the cotter pin, nut and washer off the end of the axel shaft
then you remove the 4 bolts off the back of the hub that holds it to the knuckle
once you get those 4 bolts out, there is several different ways to get the hub off. u can buy a bolt from a parts stor that threads into the back of the hub, and use a bfh and beat it out. or you can do as i did, and take a socket and extension, and have it hit the axel, and turn the wheel. causing it to push the hub out.
now that you have the hub and rotor off, its time to seperate the two. take one of your lug nuts, and thread it onto one of the lugs, and use your bfh and knock it out. then repeat on the other 7 lugs
now you have the hub and rotor seperated
next is putting the studs back in the new hub. i put the old hub on the floor, then put the new one on it, and then the rotor in place like so.
then you put the studs in. i do it this way, because the studs are longer then the hub, so trying to beat them back in, it would bottom out what ever your using before the bolts are all the way in.
when ya get all the studs set in, you take and beat the studs back in
then you put the hub back on, put the 4 bolts back in, and tighten them up, drawing the hub back into place. then you put the washer, and locking nut back on, and tighten to 175ft.lbs. then install the cotter key into the hole. if is not lined up, move the locking nut just a lil to get the hole lined up with a slot. then bend the key over.
and the finished pic
then put your brake caliper back on, then the wheel, and take her for a spin
Old Mar 29, 2010 | 01:34 PM
ArizonaRedneck's Avatar
thanks ed good writeup
Old Mar 29, 2010 | 04:49 PM
timsgsx's Avatar
awesome writeup man
Old Mar 29, 2010 | 05:30 PM
Jet A Fuel's Avatar
Nice write up Ed!! I am trying to figure out the trick you used to push the hub off the axle when you said use a socket and extension and turn the wheel you mean the steering wheel? This forces the hub off the axle? can you clarify this trick never seen it done before.
Oh and what size is the big nut?
Last edited by Jet A Fuel; Mar 29, 2010 at 05:30 PM. Reason: Automerged Doublepost
Old Mar 29, 2010 | 07:56 PM
timsgsx's Avatar
i was told the nut is 1" 3/4, correct me if im wrong
Old Mar 29, 2010 | 08:40 PM
cumminspwrram59's Avatar
they make a tool for the hub removal im goin to try it out here in the next couple weeks. i never thought of a socket and extension. thanks for the write up it will def. come in handy here for me
Old Mar 29, 2010 | 09:08 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
good write up eddy
Old Mar 29, 2010 | 11:17 PM
Yeah, good write up - but damn man, you need a new camera
Old Mar 29, 2010 | 11:45 PM
thats my phone camera
i need to get one, just never get around to it
stuff keeps breaking every time i get a lil saved up
Old Mar 30, 2010 | 09:52 AM
Good info though.
