wheel bearing hub assembly. 4wheel ABS vs non ABS
Old Mar 23, 2010 | 06:29 PM
biged681985's Avatar
Default wheel bearing hub assembly. 4wheel ABS vs non ABS
i need to change my wheel bearing hub. i have 4wheel abs, but it does not work, and i dont plan on fighting with it to get it to work any time in the future. so my question, to save some money tha i dont have, will the non 4 wheel abs unit work on one that is supposed to be on it
reason i posted here is because i need to know asap if it will work. thanks
come on yall, im sure someone knows
Last edited by biged681985; Mar 23, 2010 at 06:29 PM. Reason: Automerged Doublepost
Old Mar 23, 2010 | 08:33 PM
prromine's Avatar
Link to Napa website
RW ABS Both are the same.
Store Locator | NAPA Online
4 wheel abs has a right and left side. The spline sizes are different.
left side Dimension : 1.539" ID, w/ 33 Splines
Right side 1.538" ID, w/ 33 Splines
Hope this helps.
Paul
Old Mar 24, 2010 | 04:01 PM
went with the non ABS hub and worked great. this cn be closed mods, or moved to the 2nd gen section
oznation
Jul 28, 2015 02:54 PM
powerstroker1983
May 11, 2015 10:34 PM
jag
Tire, Wheel & Suspension
Jan 18, 2015 07:58 PM
