Adjusting the Fuel Injection Pump on a 6.9L & 7.3L Ford Diesel IDI
Old Mar 21, 2010 | 05:19 PM
Spurrit's Avatar
Default Adjusting the Fuel Injection Pump on a 6.9L & 7.3L Ford Diesel IDI
Old Mar 25, 2010 | 07:03 PM
Spurrit's Avatar
Bump it!
Old Mar 26, 2010 | 06:55 PM
CSIPSD's Avatar
I'll sticky it for now, until I have a chance to save it here...
Old Mar 26, 2010 | 07:30 PM
Spurrit's Avatar
Thanks; this is even better than the manual from Banks engineering; it was just black type on white paper. No illustrations.
Old Mar 26, 2010 | 08:45 PM
Sycostang67's Avatar
The pictures do come in handy, I used the other sticky but it would have gone quicker had there been pics.
Old Mar 28, 2010 | 09:24 AM
DieselCrawler's Avatar
just fyi that is a dumb was to check the timing. when i turn mine up i will take better detailed pics and post em up .
plus he is working on a turboed motor, the pics cant get good angles due to air box. i will get better ones
Old Mar 28, 2010 | 11:41 AM
Spurrit's Avatar
By all means, please DO show us a better way; doing things the wrong way 47 times is not as fun!
Old Aug 3, 2010 | 11:05 AM
blackcloud21's Avatar
I'm so happy to c that I am not the only one in the world with an idi.nobody around me has them. I mean I think ive seen 2 max
Old Sep 28, 2010 | 09:42 AM
ok guys, here is the updated pics.
first remove the oil fill or gear cover from this location.
u will see this
bring the stud around till it is at the 12 oclock postition like this
find the little triangle cover on the pass side of the pump and remove. dont damage the gasket. a pint or so of fuel will come out. place a rag or 2 under the pump to catch it all. will look like this
inside that hole is the adjusting screw. if the pin on the front of the engine is at 12 oclock, the screw will be visible with a mirror. will look like this.
closer veiw.
turn that screw clockwise to increase fuel. counterclock wise to decrease fuel. screw is a 5/32 allen.
Old Jul 11, 2011 | 06:50 PM
4x4manonbroke's Avatar
I have a 7.3L idi....N/A.... i have a 6" k&n filter on 14" with a 4" riser and 4" dynomax muffler..... wish there was more ways to make power with these bad *** sounding engines....... i run 2 cycle oil and atf in the tanks ..... makes a big diff.... bout a quart of atf and a half a quat=rt of the 2 cycle and she runs awesome ..... 190 hp and 385 lb/ft.... guess thats pretty good for a N/A 7.3L... what do ya'll think ?
