Mercedes Discussion of Mercedes Diesels
92 mercedes 300D 2.5 turbo?
Old Mar 20, 2010 | 01:36 PM
junkjeep's Avatar
Default 92 mercedes 300D 2.5 turbo?
I test drove a 92 300D 2.5 turbo today. The car seemed to have a knock at idle. I drove about ten miles, when I parked the car I opened the hood to locate the knock and the knock stopped. When the knock stopped it started to smoke(white) more but ran smooth and sounded normal. When I was driving the car I thought it felt under powered like the turbo was not spooling up. I am now thinking it was a stuck injector that freed itself.
Any ideas? 262,000 miles oil pressure seemed strong, temp was good. Any thoughts on the smoke?
Old Mar 20, 2010 | 09:20 PM
Begle1's Avatar
What kind of injection system do they have? Electronically-controlled rotary?
Any codes?
It could be a sensor or mechanical problem causing timing to be off, if it has variable timing. Could be a contaminated fuel issue. Could be an injector issue, but a "stuck" injector would be a miss and more noticeable; if it's an injector, it's most likely a pop-pressure problem.
I think that they all knock though.
avatardvr
18
Aug 8, 2019 12:38 AM
straight six mafia
Mercedes
Aug 21, 2015 10:19 AM
n2brk
Feb 21, 2015 09:05 AM
diesel fit her
Nov 13, 2014 02:43 PM
GreenDieselF
Oct 20, 2014 02:05 PM
