Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
HFRR : High Frequency Reciprocating Test Rig
Old Sep 5, 2007 | 11:35 AM
DB Admin's Avatar
Banned
Default HFRR : High Frequency Reciprocating Test Rig
I got this email today ... Spam or What ?
LUBRICITY TESTS FOR FUELS
Imperial offers High Frequency Test Rig
An Oscillatory friction & wear test rig in linear motion in the following models:
  • 2 Place HFRR-e ModelTWO STATION/PLACE FUEL LUBRICITY WEAR TEST MACHINE Mechanical test system
  • HFRR - Automated PC controlled High Frequency Reciprocating Test Rig for Diesel Fuel Lubricity tests Uses an Electromagnetic Drive for oscillation
  • OFT
    Fully Automated Oscillation, Friction & Wear Test Rig (Translatory Oscillation Test Rig), PC controlled High Frequency Reciprocating Test Rig
STANDARDS
IMPERIAL HFRR (all the models) are designed to conduct the following standard (& non standard)¹ tests:
For determining the lubricity of fuels & lubricants:
  • CEC F-06-A-96 : Measurement of Diesel Fuel Lubricity
  • ASTM D6079-97 : Standard Test Method for evaluating Lubricity of Diesel Fuels
  • ISO 450 : Diesel Fuel-Assessment of lubricity using the High Frequency reciprocating test rig
  • ISO 12156-1 :1997 Diesel Fuel-Assessment of lubricity using the High Frequency reciprocating test rig
  • EN 590 : 1999 Fuels- Diesel requirements & test procedures
OFT
  • ASTM D5706 Standard Test Method for Determining Extreme Pressure Properties of Lubricating Greases Using a High-Frequency Linear-Oscillation Test Machine
  • ASTM D5707 Standard Test Method for Measuring Friction and Wear Properties of Lubricating Grease using a High-Frequency Linear-Oscillation Test Machine
  • DIN 51834-1&2 Tribological tests in the translatory oscillation apparatus Part 1&2 Determination of friction and wear data for lubricating oils
¹ Non Standard here means that the equipment performs with enhanced capabilities other than stipulated in
the test standard
IMPERIAL FOUR BALL EP and WEAR TEST M/C
As per
ASTM D4172, D2596, D2266, D2783, D5183, IP239
Old Sep 5, 2007 | 11:36 AM
DB Admin's Avatar
Banned
Imperial offers 4 ball test machines to conduct Extreme pressure properties & wear tests as per variety of international standards. These machines come in a variety of configurations from economy model to fully automated 2 station Multi-purpose 4 Ball EP & Wear test machines. These machines come with stand alone configurations to fully automated (state of the art data acquisition package).
The other range includes Tribology & Petroleum Test Equipment.
Abrasion Tester, Pin On Disc, Thrust Washer, Scratch Tester, Multi-Specimen, Timken Type Test Machine, Panel Coking Apparatus, Rubber Research Test Rig, Block on Ring Test Rig,Fretting Wear Test Rig
Priced very reasonably to suit your needs and budgets
For details on Tribotesters contact :
ntincusa@gmail.com
+1(302) 338 8777
To UNSUBSCRIBE this email address from further mailings
email: ntincusa@gmail.com with message unsubscribe
robbyS
Apr 16, 2015 02:22 PM
