Trouble Starting
Old Mar 3, 2010 | 07:19 PM
Fullpull's Avatar
Default Trouble Starting
I have a 88 F350 with an International. It is so hard to start. Can anybody tell me why and how to fix it????
Old Mar 3, 2010 | 09:40 PM
CARP's Avatar
Glow Plugs. Always the damn glow plugs. Make sure you read the post on glow plug replacement. IMPORTANT!
Old Mar 3, 2010 | 09:54 PM
Fullpull's Avatar
I will, thanks
Old Mar 4, 2010 | 02:01 AM
Sycostang67's Avatar
Air intrusion into the fuel lines will also make it hard to start. When it sits, the fuel drains out and you have to crank the motor enough to refill the filter/IP. Check your return lines and make sure they dont look wet, also inspect the hard lines and around the IP for any dampness. Make sure your fuel filter is on tight as well and not leaking.
Old Mar 4, 2010 | 06:25 PM
Fullpull's Avatar
Ok, when I got the truck which was last friday, it had set for 2 years. So.... it has to be something to do with it setting.
Old Mar 4, 2010 | 08:58 PM
Then a return line kit is probably in your future.
Old Mar 4, 2010 | 09:38 PM
Fullpull's Avatar
Oh thats just lovely. How hard is it to put in???
Old Mar 5, 2010 | 07:11 AM
DieselCrawler's Avatar
easy as sunday morning, whatever the f that means.
real easy. takes 1/2 hr.
Old Mar 5, 2010 | 12:04 PM
It's a bit intimidating for a first timer, but it's really no big deal. I probably spent about 1.5 hours the first time I did it, but the 2nd time it was about 1/2 hour like dieselcrawler said. Spring for viton o-rings if you can, they stand up to the heat better and are less likely to leak.
Old Mar 27, 2010 | 06:28 PM
Spurrit's Avatar
If ya plug the block heater in, then it starts really easy, it's the damn glow plugs.
