Shade Tree , Pro-Mechanics & Fabrication Discussion of Fabrication of various products form your diesel as well as welders, Power Tools , Hand Tools , Shops, Garages , Lifts And More Including Tips and Tricks
Speedaire Compressors
Old Mar 2, 2010 | 03:41 PM
dellwas's Avatar
Default Speedaire Compressors
Anyone got opinions on Speedaire air compressors by Grainger Auckland Grainger, the Cdn division has a 7.5 hp, 80 gal two stage on for $1995, normally $3700. I believe they are built by Campbell-Hausfeld. Price includes delivery and setup in the garage, wherever I want to place it.
Old Mar 3, 2010 | 11:08 PM
Diesel Nut's Avatar
We had a Campbell-Hausfeld unit for a while. Beat on the thing for 2 years before it bought the farm. Much smaller unit, only 10 CFM, bought it from a friend. In a shop environment it was not up to the task, but in a home environment would have lasted a lifetime. Not a bad unit at all. We just had to upgrade. Now we are running a Kaeser rotary screw compressor.
Old Mar 4, 2010 | 08:27 AM
dellwas's Avatar
Thanks for the input.
I've got a small CH unit now. The speedaires are commercial/industrial/agricultural units built for Grainger to their specs. Everything I've read, including comments on a dozen forums indicates they are well built and dependable. I think I'll gopher it!
Old Mar 12, 2010 | 03:21 PM
leveled03's Avatar
we have a speedaire in our shop and its a BEAST.
Old Mar 12, 2010 | 04:42 PM
dellwas's Avatar
Thanks bud! It's here, will be delivered on Monday!
Old Mar 17, 2010 | 07:56 AM
glfredrick's Avatar
I have a speedaire that is probably 30+ years old and still purring like a kitten. What's better is that I can still get a rebuild kit and other parts for it via Graingers at any time.
Mine is a 3 cylinder horizontal model that I procured from one of my customers when I ran a Snap On truck. Traded him a used ratchet wrench for it...
Not the biggest or highest pressure unit out there, but runs quiet -- puka-puka-puka -- doesn't keep the neighbors up when I'm late in the shop. Makes a dependable 125 psi and keeps up with air tools until I go nuts with a big grinder or something.
Search speedaire compressors - Grainger Industrial Supply
Old Mar 17, 2010 | 06:41 PM
dellwas's Avatar
Well, got it yesterday and fired it up today. You're right, it is some quiet! Beats the hell out of my little 26 gal CH as far as noise goes. Man, that is some deal you got! Mine listed for $3700, and I got it for $1995, and thought mine was a good deal!
Old Apr 3, 2010 | 07:33 AM
GPM's Avatar
GPM
I'm looking to buy a compressor but have limited space & need it mostly for my 22ton jack & a couple other tools I'll be getting to help with the restoration of my Motorhome.
Quiet, Dependable & biggest bang for the buck is what I'm looking for.
Any suggestions?
Old Apr 3, 2010 | 05:32 PM
Any suggestions?
I would suggest a 25-30 gallon oil lubricated compressor. Dont get one of the oil-free ones as they dont last and are basically throw aways and are LOUD.
One like this - got mine a few years ago for $300: Porter-Cable C5512 150 PSI, 20 Gal. Oil Lubricated Horizontal Compressor
This is probably a better one: Husky 2.0 Running HP 30 Gallon Vertical Compressor - VT6315 at The Home Depot
Old Apr 3, 2010 | 07:09 PM
NadirPoint's Avatar
Originally Posted by Dr. Evil
That's the one I've had in my garage for the past two years and I use it alot. No problems so far. I've run it more or less continuously for hours on end using the cut-off wheels and grinders. Just make sure to change out the oil after the first few hours of use to get the break-in junk out of it and it will probably last forever.
