Pay It Forward Free Items Just Pay Shipping
hx40 housing
Old Mar 2, 2010 | 01:28 PM
03dieseldaddy's Avatar
Default hx40 housing
i have a brand new never used 19cm housing gated for a hx40 8 blade with T4 flange im looking for a 14cm housing for an hx40
Old Mar 2, 2010 | 01:31 PM
tltruckparts's Avatar
ive looked for that same housing for mine. ive been told that they dont make anything smaller than a 16cm housing for an hx40. hope that helps
Old Mar 2, 2010 | 06:25 PM
thanks. that sucks
Old Mar 2, 2010 | 06:28 PM
macaw's Avatar
Not sure if they still make it or not but at one time holset did make A 14cm although it is rare and hard to find and there is A few 12cm but they were an experiment that never went into regular production.
Old Mar 3, 2010 | 12:55 AM
wow id like to find one of those. ive got an 18cm right now its not bad but a little laggy.
dieseldaddy, from what i hear the 16cm housing is supposed to be the bread and butter size so maybe try and find one of those it might help ya!
Old Mar 3, 2010 | 07:57 AM
thats what i got need the some bigger nozzles to spin it it a big 40 ill get some numbers on it an maybe u guys can tell me how big it is
4" Inlet Diameter
3" Compressor Outlet Diameter
4" Exhaust V-Band Outlet
Journal Bearing - Wet Float Type
Compressor Wheel
72 lb/min Air Flow
8 Blades
Ind: 56.60 mm
Exd: 74.71 mm
Trim: 54.8
Turbiner Wheel
4" V-Band
Ind: 76 mm
Exd: 64 mm
Last edited by 03dieseldaddy; Mar 3, 2010 at 07:57 AM. Reason: Automerged Doublepost
Old Mar 3, 2010 | 01:07 PM
welderboy250's Avatar
i can tell u for sure there is a t3 14cm housing for a hx40 cause i have 2. i guess i would consider selling one but its worth a small fortune if u know what i mean. i notice a prob with the turbo u have specd out in ur last post. the compressor inducer is too small. in fact stock hx35 on a dodge is 56mm. find a 58 or 60mm wheel and housing and then u can make power.
Old Mar 3, 2010 | 01:23 PM
Hightech_Redneck's Avatar
i had a 14...... im making a hybrid right now and i upgraded the housing on my 35 to a 14..... thats if my 68 doesnt come in here soon
Old Mar 3, 2010 | 08:37 PM
the numbers must be wrong then b.c the wheel an housing were alot bigger an i noticed a big diff from stock lot more lag an once she lit theres alot more power to an i can only spin this 40 to 34psi is that b.c it to big for a single an need injectors
Old Mar 3, 2010 | 08:58 PM
the reason for only 34psi is the small compressor wheel combined with such a large exhaust housing size. a tighter exhaust housing makes more boost and quicker spool but not necisarily more power. a 56mm minor compressor is the smallest i know of for a 40. its too small for what u r doing. as far as injectors, if your talkin about the CR trucks in ur info, u dont need bigger ones to spool a 40. i can spool a 40 to over 35psi on an almost stock 1990 dodge with the little VE pump and stock injectors
