truck broke down
Old Feb 25, 2010 | 07:27 PM
ltr450's Avatar
Default truck broke down
my buddy has a 07.5 while on his way back from harrisburg it started bucking and lots all of its power and i had to tow him home. these are the codes that came up. mods done to truck all deletes and smarty 14me. i think there is a wire burn out somewhere that is causing all of the low voltages.
1.exhaust pressure sensor 1 low
2. fuel pressure sensor low
3. manifold absolute pressure senor circuit low
4. crankcase pressure sensor circuit low
5. senor reference voltage 2 low
6. fuel system over pressure relief valve activated
7. fuel rail pressure too low
8. camshaft position senor performance bank 1 senor1
anyone have and ideas
Old Feb 25, 2010 | 09:19 PM
ArizonaRedneck's Avatar
possible bad ground some where something to look at
Old Feb 25, 2010 | 09:23 PM
BLACK RHINO's Avatar
If your hunting A wiring issue then have A look at the serpentine belt. And any of the wires running round close to it. the wires too and around the AC Compressor were A common sticking point in the earlier units. Haven't had to crawl mine yet to see if this has potential or not. But may give you something to look for. Good thing to do is check fuses and what else is connected to them for the control of the things blowing codes. See if there is A common underlying connection.
Rhino.
Old Feb 26, 2010 | 06:37 AM
Horse Power's Avatar
Rhino.
My truck has the wires around the AC Compressor all messed up. Will the dealer fix this or do i have to?
Old Feb 26, 2010 | 09:36 PM
Should be warranty work. Depends on the cause.
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
bdemutis
Oct 15, 2014 11:09 AM
Oct 14, 2014 08:40 AM
