Torque spec for fuel injection lines
Old Feb 25, 2010 | 09:52 AM
wlrdlr49's Avatar
Default Torque spec for fuel injection lines
What is the torque for the injector feed lines that go thru the valve covers. THANX
Old Feb 25, 2010 | 10:41 AM
2500HeavyDuty's Avatar
i believe its 30lb ft using a crows foot.
Old Feb 25, 2010 | 06:57 PM
wlrdlr49's Avatar
Thanx for the reply! How critical is it to torque the feed & return lines? I don,t have a torque wrench.
Old Feb 25, 2010 | 09:22 PM
too loose and it will leak and the high pressure lines will leak disel fuel into the oil. too tight and you can torque the injector so hard it will twist and it will mess up the return line seal.
the return lines too loose and it will leak, too tight and you will strip the bolt.
