can it be done?
Hey i got an 1988 e350 28 foot motor home it has no od. I would like to put the trans out of my 92 f350 witch has od in it i have everything to go with it can this be done? Also was looking for a power setup to put on it. Any help would be great
You can also use a Baumann controller for the transmission if you dont want to swap the electronics. One of the benefits is that if your tachometer stops working, your transmission wont go into limp mode.
Baumann makes stand alone controllers for electronically shifted 4speed automatics. Without it or swapping in the factory electronics, the transmission wont shift right and kill itself rather quickly.
TCS Detailed Product Description - Baumann Electronic Controls, LLC
