7.3 if cold wont start
Old Feb 18, 2010 | 08:25 PM
redneckunleashed's Avatar
Default 7.3 if cold wont start
i have a 2001 f250 7.3 diesel. it will not start in cold weather. i have had glow plugs tested all of them are good. can some one give me a idea of what it could be. cuzion has the same truck one year older same engine and his starts right up nomatter what the weather is he took it up to ohio and it started right up. i cant even get mine to start where i live in florida
Old Feb 19, 2010 | 12:29 AM
Diezel Dawg's Avatar
Glow Plug Relay??
Old Feb 19, 2010 | 05:13 AM
someone told me if the wait to start light stays on for a long time it is not the relay switch. can u test that relay
Old Feb 27, 2010 | 12:25 PM
powerstroke 7.3's Avatar
have a 2000 7.3 with about the same problem....in Georgia....if I plug it in at night or for about 30 min after an overnight...it starts fine...but if not plugged in very hard or won't start....have been told I need to replace the fuel pump...that will be done in the next week...
Old Feb 27, 2010 | 06:43 PM
JIMS 03 73's Avatar
TEST YOUR GLOW PLUG RELAY. MOST LIKELY ITS BAD. SHOULD BE ONLY LIKE .2-.3 VOLTS DIFFERENCE BETWEEN STUDS. ITS ON THE PASSENGER VALVE COVER IN BEHIND THE POWERSTROKE COVER. BE CAREFUL CAUSE THE AIR INTAKE HEATER IS RIGHT THERE ALSO AND THEY LOOK THE SAME. IF MORE THEN THAT THEN ITS BAD.
Old Feb 28, 2010 | 12:33 PM
DieselDanBoy's Avatar
here's a simple way of doing it.
take a screwdriver and cross the relay terminals, the relay is located on the passenger side of the motor on top under the powerstroke cover. if you cross it for about 10 seconds and crank it over and it starts, your relay is bad.
post what you find, ill garuntee its the relay.
Old Feb 28, 2010 | 02:18 PM
triton's Avatar
NADM Member
I've had the same problem with my 7.3. Changed the GPR and GP's and it still did it. I've been told it's the nature of a 7.3 to not like it in the cold weather. Single digits to 20's for weeks at a time is what I'm dealing with. Since you're in Fla, I'd guess GPR too.
My resolution.... a shot of starting fluid ( always keep a can with you ). Starts every time no matter what the temp. It does need to stay plugged in though when that cold.
Old Mar 1, 2010 | 07:29 AM
yea if you want holes in your pistons and bad rings......
Old Mar 1, 2010 | 07:53 AM
JIMS 03 73's Avatar
SWITCHING TO SYNTHETIC WILL MAKE A HUGE DIFFERENCE IN THE COLD. MINE HATTED STARTING B4 I SWITCHED. I DONT NEED TO PLUG IN AT ALL HERE IN MAINE. DONT USE THE EITHER THOUGH. YOUR ASKING FOR TROUBLE. HOW ARE YOUR BATTERIES? THESE MOTORS TAKE A LOT OF JUICE TO GET FIRED UP IN THE COLD.
Old Mar 1, 2010 | 07:56 AM
synthetic oil? of course it will because its thinner and it flows better.
lets try testing this relay......
