Diesels On The Dyno Diesel Discussions of Dynoing , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST EVENTS IN THIS SECTION*
What kinda power am i making?
Old Feb 14, 2010 | 10:31 PM
justinb12's Avatar
Default What kinda power am i making?
Man this might be dumb '?' but i'm curious. What kinda of power might i be making? My mods are: Hx40 downpipe, cone filter on the turbo, closed wastegate, 370marine injectors, no fuel plate, turned up injector pump(215hp) (not sure what my friend did but it was while we was taking the plate out) 4in exhuast and the rack back trick. Well i'd appreciate any and all thoughts.
Old Feb 14, 2010 | 11:31 PM
mainman300's Avatar
? run it on the rollers man its cheap that way you will know for sure.
Old Feb 15, 2010 | 03:48 PM
94 12valve's Avatar
I hope you will be makeing horsepower.
I have a few questions. What turbo are you running( I see the hx40 downpipe so I assume its not stock)? What did your friend do to your injector pump? What is the " rack back trick"?
Old Feb 15, 2010 | 05:31 PM
justinb12's Avatar
I know the turbo's stock. The fuel rack trick is where you push the rack in the injection pump forward for more hp or back for less. I talk to my friend and thats what he told me he did. So thats what i typed. I should have edited for better info.
Old Feb 21, 2010 | 10:17 AM
Cameron's Avatar
sounds like he slid the fuel plate forward.
Old Feb 21, 2010 | 10:33 AM
rkrussell's Avatar
The rack is not stationary. It moves back and forth. The only thing you can do is put a new plug on the front of the pump so it has more travel. Just a guess though..
Old Feb 21, 2010 | 09:09 PM
justinb12's Avatar
The question again was. How much power? Whats the census on that?
Old Feb 22, 2010 | 11:05 AM
94 12valve's Avatar
how are we suposed to guess if we don't know everything you have done?
Best way to tell is just strap her down and spin the rollers
Old Feb 22, 2010 | 08:40 PM
justinb12's Avatar
True. I should just go do it. I was just after a ballpark if anyone else has those mods. Its hard for me to do anything in PA when my home of Texas is so far away. I am sure they have them up here to but if it was to break i'd need to get it back home.
Old Feb 23, 2010 | 05:58 AM
94 12valve's Avatar
where in PA are you? there is a dyno event in dillsburg on march 20th and 21st
