2000 f 250 7.3d front end roaring and vibration
Old Feb 14, 2010 | 12:13 PM
jodyr2003's Avatar
Cool 2000 f 250 7.3d front end roaring and vibration
need help to diagnose a front end vibration and roaring sound. think its the hub assembly do to i have a abs light on and the vibration and roaring sound. i read alot of post and it seems to be hub assembly bearings. ive already changed ball joints. can you guys help.
Old Feb 15, 2010 | 08:01 PM
ArizonaRedneck's Avatar
welcome to diesel bombers jack up the front of your truck to get the wheels of the ground and spin your tires and see if one feels funny or makes a lot of noise
Old Feb 15, 2010 | 09:13 PM
Begle1's Avatar
Violently shake the tires back and forth while you're at it.
The "correct" way would be to put a dial indicator on things and check for maximum hub play in any direction... In practice that means shake them like babies until you hear what the problem is.
Old Feb 16, 2010 | 02:32 PM
jodyr2003's Avatar
Default thanks for advice
I WILL DEFINATELY TRY THIS. WHILE I'M TRYING TO DIAGNOSE AND FIX WHAT'S A GOOD SHOCK FOR THIS FORD F250 SD TRUCK.:
