Mercedes Discussion of Mercedes Diesels
85 300d pours tranny fluid
Old Feb 11, 2010 | 05:28 PM
moneyman_09's Avatar
Default 85 300d pours tranny fluid
So the other day i was doing the daily running i drove probably 30 miles parked at a station to fill up left it running came out and noticed tranny fluid was coming out in a stead stream i bought more and luckly made it home but have am not sure if i cracked the pump or the torque converter or where to find parts that don't cost more than i paid for the car.
Thanks for the help.
Old Feb 11, 2010 | 07:51 PM
ArizonaRedneck's Avatar
is it coming from under tranny or engine somewhere could be tranny lines that run to and from cooler
Old Feb 12, 2010 | 05:56 AM
oldsinner111's Avatar
Putting trans fluid in a Benz takes time.You have to wait for the fluid to warm,and run down dipstick hole.If you don't it will over fill,and pump seal will push out.Pan gasket will usally save your pump.Dipstick hole can leak,and modulator.Lets hope so easy fixes,as lines too.
Old Feb 12, 2010 | 09:37 AM
I have only owned the car like a month i drove it home from muncie checked the trans fluid when i got it home and it was fine so i never added any i checked the lines it's pouring from the bell houseing vents. It always felt slugish compared to my 300sd
Old Feb 12, 2010 | 10:30 AM
you might try blowing thru radator trans cooler.I usally disconnect and add a aftermarket cooler.Sometimes lines in rad will rust or worse fill with anti freeze.
Old Mar 3, 2010 | 10:27 PM
It was the front seal. I sold the car to a friend he will have it back on the road real soon
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
smokee
Nov 7, 2014 07:40 PM
