Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
jp8
Old Feb 10, 2010 | 08:57 PM
Tinman875's Avatar
Default jp8
Here you go guys this may answer some questions about "what" JP8 is. Hope it helps.
Dear Mr. Anderson,
Thank you for contacting ExxonMobil.
We received this information to pass on to you.
The four fuel products mentioned by the customer are governed by different
specifications in the US: Jet A by ASTM D1655; JP8 by MIL-DTL-83133F; #1
diesel and #2 diesel by ASTM D975
Jet A is the commercial version of aviation turbine fuel used in the US.
JP8 is the version of Jet A used in US military applications. JP8 is
essentially the same as Jet A, except JP8 has better low-temperature
operability and JP8 must contain icing inhibitor, corrosion inhibitor,
lubricity, antistatic, and antioxidant additives. Jet A may or may not
contain one or more of these additives. The hydrocarbons in Jet A and JP8
must be derived from refining of conventional sources, such as crude oil.
Recently, approval has been given for up to 50 vol% of these fuels to be
synthetic paraffinic kerosene derived from a Fisher-Tropsch process (as
described in ASTM D7566 and MIL-DTL-83133F).
#1 diesel fuel is somewhat similar to Jet A in composition and distillation
characteristics. However, #1 diesel fuel is available in 3 sulfur grades:
15 wppm, 500 wppm, and 5000 wppm maximum sulfur, respectively. Jet A is
available in only one sulfur grade with a 3000 wppm maximum. Jet A is
allowed to have up to 25 vol% aromatics, while #1 diesel fuel is permitted
to have up to 35 vol% aromatics content. Thus, #1 diesel fuel usually has a
higher content of aromatic compounds compared to Jet A.
#2 diesel fuel has a lower volatility than #1 diesel fuel, and #2 boils
over a wider range. The T90 distillation recovery temperature of #2 diesel
fuel is specified to be as high as 338°C maximum, while for #1 diesel fuel
T90 is permitted to be 288°C maximum. #2 diesel fuel is available in the
same three sulfur grades as #1 diesel fuel and may also contain up to 35
vol% aromatics.
#1 and #2 diesel fuel are permitted to contain up to 5 vol% biodiesel
(mono-alkyl esters of long chain fatty acids derived from vegetable oils or
animal fats). Biodiesel is not permitted in jet fuels.
Ian George
Exxon Mobil Corporation
Note: When responding to this message, please use reply to keep the email
thread intact. We need to see the information on previous e-mails to
better assist you. Thank you.
The information contained in this message may be confidential and may also
contain privileged solicitor-client information or work product. The
information is intended only for the use of the individual or entity to
which it is addressed. If you are not the intended recipient, or the
employee or agent responsible to deliver it to the intended recipient, you
are hereby notified that any use, dissemination, distribution, or copying
of this communication is strictly prohibited. If you have received the
message in error, please notify us by telephone at 1-800-243-9966
immediately. Thank you.
The following inquiry was sent through:
Brand: EXXON
First Name: Jason
Last Name:
Position Title:
E-mail: tinman875@cableone.net
Company: Conrad & Bischoff
Address:
Country: United States
Phone:
Fax:
Current Customer: Yes
Question:
what is the compostition difference between JP8 JET A #1 diesel and #2
diesel? Thanks Jason
