Wont start
Old Feb 10, 2010 | 05:30 PM
epowers777's Avatar
Default Wont start
need help 7.3 Lf350 just bought 3 weeks ago wont start. It cranks then sounds like it wants to start but just cranks. I checked all fuses fuel bowl full and pump is working. the waite start light does show and turn off and the check engine light is not on. I do not have a scanner to test codes. Pls help
wiggled some lines on fuel tank and got the truck started barely made it to the garage no power and missing.Leak in fuel line? they just replaced the sending unit. Can I get codes without a code reader?
Last edited by epowers777; Feb 10, 2010 at 05:30 PM. Reason: Automerged Doublepost
Old Feb 10, 2010 | 05:50 PM
Diezel Dawg's Avatar
CPS?
Old Feb 10, 2010 | 05:58 PM
epowers777's Avatar
Note to self never let truck get below 1/4 tank :doh::doh::cursin:. It got air in the line. cycle key 5 times then drain valve while cycling don work. To properly bleed fuel system.....:fyi:
if you have access to an air line tightly wrap a shop rag around a blow tube and stuff it into the fuel filler. Have someone release the bleeder vale on the injector rail while pressurizing the fuel tank. This will force fuel into the line at low pressure [The rag will loose some but not all the pleasure applied] and bleed the air out of the line. When fuel [with no sputtering] is flowing out of the bleeder tighten it down and you should be good to go.
Old Feb 10, 2010 | 11:02 PM
CSIPSD's Avatar
... Or just cycle the key a few times and be done...
Old Feb 11, 2010 | 12:14 AM
epowers777's Avatar
I cycled the keylike 20 times do you know why itdidnt work?
Old Feb 11, 2010 | 06:38 PM
CSIPSD's Avatar
I would guess your pick up could be plugged or your fuel pump is getting weak.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
