Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
Decal Help
Old Feb 10, 2010 | 12:20 AM
mopo824's Avatar
Default Decal Help
When i bought my truck the decals were removed except for the cummins "c" and i want to remove this can anyone help so that i dont hurt the paint. Also i am wanting to put a cummins sticker on the back any tips on that because the last one i bought tore while i was peeling it off the paper to put it on my window.
Old Feb 10, 2010 | 12:33 AM
Easy, use some fishing line in a sawing motion behind the plate. This should get the item off. Next use some adhesive remover, or WD-40 to get off any glue residue. That or you can use a 3M decal remover wheel. available from an autobody supply place or summit racing or Jegs.
More info here: https://www.dieselbombers.com/diesel...k-remover.html
and here: https://www.dieselbombers.com/diesel...ck-decals.html
There is an excellent "how-to" for installing stickers - I will see if I can find it for you.
Old Feb 10, 2010 | 01:23 AM
mopo824's Avatar
thanks i appreciate it
Old Feb 10, 2010 | 09:54 AM
found it:
https://www.dieselbombers.com/web-si...selminded.html
Old Feb 21, 2010 | 10:22 PM
DA BUS's Avatar
You can also consider a heat gun first, before the fishing line, then WD40....
Good luck!
