injectors
Yes, bb code injectors are pretty popular, make sure who ever you get injectors from pressure matches them.
There is a sensor on the t-case for the 4wd light, check the wiring under the truck and make sure it's still plugged in.
You can put a 6spd on the IDI, but it takes some fab work. The transmission tunnel needs to be worked and I think the ZF6 has coolant running through it. The people who have done it claimed the benefits weren't worth the effort.
Stay away from DPS, heard nothing but bad things about there IDI injectors. Pennsacola is supposed to be good. There is also a guy on oilburners(typ4/Russ) who sells matched BB codes for under $300 shipped.
