low Boost High egt's
Old Feb 6, 2010 | 08:58 AM
slosh2500's Avatar
Default low Boost High egt's
I have an 02 auto with and edge comp and injector tips. i recently put guages on it and am only seeing 24 pounds of boost at WOT. Is that right? Also if someone could give me a hint how to setup up my "sig"
Old Feb 6, 2010 | 09:37 AM
RAW's Avatar
RAW
24 lbs is about what i see with my 60hp nozzles, and Edge Juice on level 6. That HY35 turbo won't make anymore without wastegate modifications (assuming you are still running the factory turbo).
As for the signature, click on "User CP" in the black menu bar. Thisa will drop down a menu, click "Edit Signature"
Hope this helps.
Old Feb 6, 2010 | 10:14 AM
tearin_it_up_everywhere's Avatar
I was seeing with my hx35 35psi when i had my adr on pl6 and got into it hard
Old Feb 8, 2010 | 04:47 PM
01trailerpuller's Avatar
With my old HY that I had a boost elbow on I could hit 35 with my edge on 5 and 40hp injectors. My egts would go through the roof fast.
For your sig click on this https://www.dieselbombers.com/profil...=editsignature
Old Feb 13, 2010 | 04:47 PM
cumminscrazy21's Avatar
when i was runnin stock charger and boost elbow only with the adrenaline on the truck i could hit 40 with no prob so if you want more boost buy you a boost elbow...it is a cheap but great product and well spent 30 bucks
robbyS
Apr 16, 2015 02:22 PM
kraftsman
Ford Powerstroke 08-10 6.4L
Mar 4, 2015 02:00 PM
chaoticape
Jan 4, 2015 05:35 PM
cameronlee51
Oct 28, 2014 12:33 AM
offroad00
24
Oct 23, 2014 03:28 PM
