testing relays
Old Feb 2, 2010 | 08:16 PM
topel's Avatar
Default testing relays
On 2000 7.3 will not start below 30 degrees if not pluged in. I have replaced glow plugs and still same issues.Now i am trying to find the real problem before wasting more time and money.there are two relays there. one seems to go to intake, is this a heat element also? I assume the other is glow plugs? I have tried testing both and they test the same. I have 12 v on large stud comming in and two small studs on each test 12 v all the time also.The large stud i think goes to gp and intake i test 0 v all the time even when key is first turned on and engine is cold 40 degrees.
Old Feb 4, 2010 | 12:38 AM
ArizonaRedneck's Avatar
eBay Guides - Ford diesel glow plug relay trouble shooting this has quite of good info see if it will help with your problem
Old Feb 4, 2010 | 07:38 AM
DieselDanBoy's Avatar
you should have two relays, one on the passenger fender and one on top of the motor next to the fuel filter/bowl. the one on the motor is the one for you gp's, your relay is most likely bad so just buy one for 40$. that should be your fix, there are no intake heater elements on powerstrokes.
Old Feb 7, 2010 | 10:04 AM
topel's Avatar
ok thanks
guys
Sep 29, 2015 12:50 PM
Aug 23, 2015 06:10 PM
Jul 8, 2015 05:50 PM
Feb 16, 2015 02:00 PM
Jan 20, 2015 03:01 AM
