'99 7.3l won't crank
Old Jan 31, 2010 | 09:10 PM
03-7.3's Avatar
Default '99 7.3l won't crank
Hi Guy's I'm having problem's with my 7.3 not cranking with the ignition key . With the key on I can jump it on the starter solenoid and start's like normal . I've checked fuses and changed the starter solenoid with no effect . Anywhere else I can look for a problem ?
Old Jan 31, 2010 | 09:15 PM
PSD's Avatar
PSD
I have the same problem sometimes. Turn the key and just a tick, but I can jump it on the solenoid. Hasnt happened lately though. Curious to see what people have to say.
Old Jan 31, 2010 | 10:34 PM
03-7.3's Avatar
It's a pain for sure !!
Old Feb 1, 2010 | 12:23 PM
dixierebel0213's Avatar
pull the steering column apart and check your 12v supply to ignition. if you have 12v then jump 12v supply to your starter solenoid feed wire, if it starts the replace the ignition switch if it doesnt you have an open circuit from your ignition switch to solenoid. if you raise and lower the steering wheel alot then chances are you have a broken wire in column due to continuous flexing
Old Feb 3, 2010 | 04:41 PM
gradyc's Avatar
You didn't say whether it is an automatic or standard. If it is automatic there is a neutral safety switch that can be bad and if it is a standard it has a clutch interlock switch.
Old Feb 3, 2010 | 07:42 PM
03-7.3's Avatar
Tks guys I'll try your suggestions
Old Feb 4, 2010 | 11:36 AM
you can disconnect the clutch switch and stick a paper clip between the two terminals to check it
Old Feb 11, 2010 | 08:31 PM
03-7.3's Avatar
Hi Guy's thanks for the help . The problem ended up being the tranny MLP sensor was NFG , it had taken on water and was corroded inside .
SkiDooGuy
Sep 9, 2015 05:55 PM
ish1521
Aug 26, 2015 08:42 PM
88 f350 7.3 idi
Aug 20, 2015 09:18 AM
Kooper
Jul 15, 2015 12:11 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
