lifting the front
Old Jan 30, 2010 | 03:42 PM
BAD ASS RAM's Avatar
Default lifting the front
i am going up in tire size and i was wondering is there any way i can lift the front without spending big bucks on a suspension kit.it seems like i could just get longer springs or taller spacers,just wanting to know from somebody that has done it before.
Old Jan 30, 2010 | 06:59 PM
12valvetater's Avatar
Hell bent steel makes a leveling spacer for not a whole lot.
Old Jan 30, 2010 | 07:07 PM
bowdiesel's Avatar
ADD A LEAFS FROM ROUGH COUNTRY FOR THE REAR ....AND SPACER BUSHINGS FOR THE FRONT.... Dodge Suspension Lift Kits HELPED NEIGHBOR INSTALL THIS KIT ......JUST NEED A COIL COMPRESSION TOOL ...YOU CAN RENT FROM AUTO ZONE .....YOU WILL GET ABOUT 1.5" FROM THIS KIT
Old Jan 30, 2010 | 07:33 PM
wes-cummins's Avatar
theres alot of places that sells leveling kits, i would put air bags in the back if you want to lift the back
Old Jan 30, 2010 | 07:50 PM
Hammer's Avatar
295/70/17's are 33.5 inches tall and you could go to a 35 inch tall tire with just the addition of a leveling kit up front.
Either a set of of leveling blocks or a set of SkyJacker D25 coils and you will get the needed height for the 35 inch tire.
Old Jan 30, 2010 | 09:10 PM
dieseldocter16's Avatar
I got a set of 2" leveling pucks off ebay for $65.00 and I'm currently running a 315/75/R16 tire.
Old Jan 30, 2010 | 09:29 PM
TwinStackPete379's Avatar
Dont let Logan see this
Old Jan 31, 2010 | 12:10 AM
Cody Cummins's Avatar
A leveling kit in the front is what ya need, If you plan on lifting it any further get a kit, but whatever you do don't put blocks in the back!
Old Jan 31, 2010 | 11:29 AM
i've already got a pacbrake leveling kit,all i want is about 2-3 more inches to clear 37's
Old Jan 31, 2010 | 04:11 PM
They say that 3rd gen coild are suppose to lift the truck 4.5 or 5 inches.
