7.3 Fuel Leak
Old Jan 25, 2010 | 07:41 PM
Sean O'Neal's Avatar
Default 7.3 Fuel Leak
Throwing this out there to see if I can get some help. Leaking fuel on the top of the engine and I have narrowed it down to the fuel cap. Questions are these?
1. Do I have to replace the cap or will the O-rings do?
2. Where do I get the O-rings?
3. Should the fuel heater be replaced also?
4. (this one has nothing to do with fuel leak) I just got the factory recall on the Camshaft Placement Shiftor Censor. I had the work done, will that help with cold cranking?
Look forward to the replies.
Sean
Old Jan 25, 2010 | 08:02 PM
muskrat's Avatar
Old Jan 26, 2010 | 03:20 AM
97cummins's Avatar
If you put your question in the ford powerstroke section you'll get a better responce.This is the introduce yourself part.
Old Jan 26, 2010 | 03:50 AM
coyropin's Avatar
Old Jan 26, 2010 | 03:55 AM
turbo20psi's Avatar
Welcome to DB.
Old Jan 26, 2010 | 06:38 AM
mishkaya's Avatar
If you ask your question here you will get a better response:
Ford Powerstroke 99-03 7.3L - Diesel Bombers
Old Jan 26, 2010 | 06:49 AM
ugly truck's Avatar
Ford put crush washers on the back side of the lift pump and they have been known to spring a leak on costly may be 10 to 15 dollars for the set but a pain in the tail section you have better have a large wrench also. it might be the lift pump might be going bad costly but not hard to do your self. check out the new diesel power mag Jan 2010 Page 116 and runs to 122 that might be anther fix if the years are right. ON the 2nd question no the crank censor will not help only the block heater in cold weather or a heated shop.
Old Jan 26, 2010 | 08:50 AM
01trailerpuller's Avatar
Good luck with your problem.
Old Jan 26, 2010 | 08:54 AM
ArizonaRedneck's Avatar
welcome to diesel bombers the#1 diesel site around
Old Jan 27, 2010 | 12:31 PM
DIESELDENT's Avatar
Welcome to db
