6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
Best EGR Delete Thread
Old Jan 21, 2010 | 01:41 AM
ATX6132's Avatar
Default Best EGR Delete Thread
Lets get this EGR delete stuff solved..everyone put there best imputs and wat exactly the EGR Delete is best for and needed for..
And I myself also have a question..which EGR delete is better?
EGR Delete System or EGR Delete Kit
or am i just that dumb and there the same
GoGoDiesel EGR Delete System The most advanced EGR delete system for your 6.0L Powerstroke.
or
BD Diesel EGR Delete Kit for 03-07 Ford Powerstroke 6.0L
Im for sure gettin this done for my truck within the next 2 weeks.. so i would highly appreciate the inputs, also suggestions on doin it myself or mech.?
Old Jan 21, 2010 | 04:17 AM
HeavyAssault's Avatar
Boy this is going to be good.....
I'm going to be using the GOGO Diesel manifold myself when I swap my oil cooler. I prefer the removal of the coolant channel and routing it directly back to the bottle. Since there no clamps for the hose there shouldn't ever be a leak issue. IF you need to run the EGR valve for a visual inspection you can have your EGR valve in place and not worry about operation. Cost is worth the extras to me.
I feel that all the kits available are quality kits just some have more thought put into the design. Some will let their pocketbook decide, others will decide based upon an educated decision.
Old Jan 21, 2010 | 07:26 AM
BC06PSD's Avatar
Gogo's kit is probably the best one out there.
Old Jan 21, 2010 | 01:10 PM
ATX6132's Avatar
Thanks guys hopefully we get alot of info on this.. wat yall think bout installing myself or goin to a mechanic
Old Jan 22, 2010 | 06:45 AM
What past experience do you have turning wrenches? I'm going to swap my oil cooler and manifold soon.
Old Jan 25, 2010 | 11:26 AM
Mikaela@DieselNut's Avatar
Jason's helper
For those of you who do not want to DELETE your kit, Bulletproof Diesel has an outstanding upgraded cooler kit that includes Egr Cooler, Oil cooler, and all gaskets. We recently added them to our vendor list and have had a great response to them. If anyone wants some more info just shoot me a PM.
Old Jan 25, 2010 | 02:45 PM
grabber1's Avatar
So to clears things up...which of the 2 is the best to use?
Old Jan 25, 2010 | 07:07 PM
04redstroker's Avatar
If your short on cash, you can always just go get a couple freeze plugs and weld the cooler up. That way no exhaust enters, its still there for emissions (if they dug that deep), and even if its leaking it cant go anywhere. Not the best way to fix it but it works. I might go with the gogo stage one intake when i do studs, and other goodies.
Old Jan 25, 2010 | 07:31 PM
GOGO Diesel will be getting my order real soon!!
Old Jan 26, 2010 | 12:11 AM
Mdub707's Avatar
There's a million ways to do this, and a million different "kits" to accomodate every way. I think the River City Diesel is a nice inexpensive setup. I think FCDP has a very nice setup, but you cant return to stock unless you buy a new intake manifold (which is still OK for some people), and GOGO's setup is pretty trick too, but a lot of $$$.
I will probably either make my own or go with the RCD one myself, but it's all preference. Each has their plus' and negatives.
