dual turbo or single on the dmax?
Old Jan 20, 2010 | 06:23 PM
cfarley0210's Avatar
Default dual turbo or single on the dmax?
what do you guys think about the dual turbo setup on a dmax?
or should i just do a upgraded single turbo? i would love to have the dual turbo setup but i was just curious if anyone else has had that setup, and if they would reccomend it or not?
Old Jan 29, 2010 | 02:10 PM
delong_1's Avatar
ive had several singles and the coupound set now. imo it really depends on your plans for the truck.
Old Jan 29, 2010 | 03:43 PM
5.9Bronco...eventually's Avatar
I cant see any reason that if you have the money not to get the twins. better spool up, bigger numbers if you want to go bigger, sounds like a jet. I dont know though thats just my thoughts
Old Jan 29, 2010 | 09:39 PM
CumminsPower127's Avatar
id go with the compound.but idont really know.more power obviously.then get bigger injectors
Old Jan 30, 2010 | 11:19 PM
i think i am going to go single for now and i can allways double it later. money is kinda tight, but i am having a hard time deciding if i want a bd turbo or a aroura 3000 or 4000. i would like to push atleast 45#of boost and i want to have a quick spool still. i would perfer quick spool over the 45# of boost. what would you perfer? every opinion will be apreciated.
Old Jan 31, 2010 | 08:05 AM
cmnspwr05's Avatar
bd is an awesome turbo...they construct their turbos to put the right amount of air through them for each truck. I'd do that and then stack another one down the road
Old Jan 31, 2010 | 01:37 PM
2500HeavyDuty's Avatar
Id look into getting the HTT ss turbo. Spools faster than stock and it flows more then enough air for what ur looking for
Old Mar 4, 2010 | 07:53 PM
delong_1's Avatar
either the bd 64mm or the htt 66 would be a good choice, the htt 66 is what i run as my high pressure turbo.
Piedmont Mobile Mechanics
6.4L Performance
Jul 17, 2015 06:35 PM
n2brk
Feb 21, 2015 09:05 AM
Alfred Bruce Millett
Dec 19, 2014 05:17 PM
GreenDieselF
Oct 20, 2014 02:05 PM
