head removal and studs
Old Jan 12, 2010 | 11:28 PM
drivecumminsridered's Avatar
Default head removal and studs
i have finally came up with the money to buy head studs and have the head o-ringed and all the other stuff that goes along with this project. anyways i was wondering how hard it is to remove the head. i have removed heads on tractors, dozers and things like that but never on a pickup. also any suggestions, tricks and tips on what i should do would be greatly appreciated. thanks
Old Jan 13, 2010 | 12:07 AM
12valvetater's Avatar
Easy just a pain trying to weasel it under the cowl without damaging the headgasket. I don't care what any body says do not retorque the headstuds hot, or even warm. Let them cool ALL the way back down.
Old Jan 13, 2010 | 12:20 AM
thats what i figured. thanks for the tip!
Old Jan 13, 2010 | 07:06 PM
stillbad's Avatar
its very simple, even easier with the help of a cherry picker if your the only one working on it. why do you say not to re torque the studs warm 12valvetater?
Old Jan 13, 2010 | 07:30 PM
joey's Avatar
Bcause the head studs will strech when hot or warm.
Old Jan 13, 2010 | 07:37 PM
Ya its better to let the truck get some heat cycles in before you do.
Old Jan 14, 2010 | 12:44 AM
The stud is not designed to be stressed while hot. I think the reason that people are having issues with the studs breaking is because for one they over torque them and the retorque them while the stud is hot. They say that whe the engine is warm it allows greater crush of he headgasket. I say follow the manufactures guidelines on proper installation. But then what do I know.
Old Jan 15, 2010 | 12:31 PM
stillbad's Avatar
Ok thanks for explaining that to me. I think i done mine right, before final torque i let the truck idle up to operating temp an then cool completly back down.
Old Jan 15, 2010 | 01:10 PM
94 12valve's Avatar
to get the pushrods out on # 5 and 6, there are holes cut in the cowel covered by a rubber insert
Old Jan 15, 2010 | 11:33 PM
seandonato73's Avatar
what are you torqueing thhem too?? 125 lb ft 140 lb ft?
