PPE Boost Valve with stock turbo?
Old Jan 11, 2010 | 01:05 AM
LB7DuramaxMeggers's Avatar
Default PPE Boost Valve with stock turbo?
i have seen quite a few people with boost valves on their lb7's. now i read stock the turbo pushes out 18-20psi. then after the boost valve it pushes out 28-30, nearly a +10 increase. will this do damage to my turbo? or even my tranny?
Old Jan 17, 2010 | 06:57 AM
2500HeavyDuty's Avatar
If you have stock tuning it wont do any damage, you can push the stock turbo without the boost valve to over 30psi with more fuel. You might see a little more power increase with it with that alone, but don't expect anything you can feel by the butt-o-meter.
the max the turbo can take is about 32psi at sea level before it is being over spun.
Str8sixpack
Feb 28, 2015 11:32 PM
n2brk
Feb 21, 2015 09:05 AM
LTreis702
Feb 14, 2015 12:52 PM
Crews8r
Dec 21, 2014 07:35 AM
GreenDieselF
Oct 20, 2014 02:05 PM
