first got an oil change
Old Jan 6, 2010 | 10:35 AM
bbqbuzz's Avatar
Default first got an oil change
then the next day the cel lite up--checked the codes--there were 4--P0116--P0181--P0700 &P2199 plus the cruise control doesn't work! What did the shop do?? figuring they must have knocked something loose but what?? They are a pretty good shop but unfamiliar(I think) with most diesel stuff
Usually change the oil at home but am too old and fat to lay under the truck when the temp is below zero(f)
thanks for any help
buzz
Old Jan 8, 2010 | 02:26 AM
biged681985's Avatar
the codes dont seem to be stuff that they coulda realy messed up there. the fuel one could be that the didnt plug the sendor back into the bottom of the fuel filter. other than that, first thing id do is call them up and tell them u think they may have knocked a wire loose, and u want the to look and make sure. good luck
Old Jan 8, 2010 | 09:24 AM
chpmnsws6's Avatar
Take a look around the oil filter, the fill, and the drain plug. If no sensors are broke or unplugged, chances are the problems are unrelated. They want to get you in and out as quickly as possible, and not see you again for 2900 miles.
Old Jan 8, 2010 | 06:56 PM
outdoors guy's Avatar
The cruise control could be a blown fuse. It's the same fuse for the horn so check the horn if it works then you know the fuse is ok.
Old Jan 11, 2010 | 11:44 AM
bbqbuzz's Avatar
thanks for the replys--will stop buy shop when in town tomorrow----and the horn works
thanks again--first brisket is on me!!
Old Jan 16, 2010 | 04:54 PM
wildbill's Avatar
Fixed??
wlofton
11
Jun 26, 2018 08:58 AM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
J_stout
Feb 21, 2015 11:40 PM
