Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Vibration coming throughout the truck, need your oppinion
Old Jan 1, 2010 | 03:47 PM
HeavyChevyDMAX's Avatar
Default Vibration coming throughout the truck, need your oppinion
Well first i got a squiking noise coming from the center of the truck from underneath and its in sequence with the drive shift spinning... would that be a u-joint startin to go??
and i also have a slight vibration in the truck, you can mainly feel it through the steering wheel when im on the gass, but once i let off it goes away and it only happens when im doin 30+ mph it gets really bad when im doin 80 haha. rear view mirror starts to rattle and stuff. would that have somethin to do with the possible u-joint problem??
what do you guys think?
Old Jan 2, 2010 | 02:18 AM
dieseldocter16's Avatar
Yeah check your u-joints to see if they're loose and as far as the vibration in the steering check the cv shafts and tie rod ends.
Old Jan 7, 2010 | 01:16 PM
redneckbuckeye's Avatar
U joints in the drive shaft, also you have the crew so it should be the two piece rear drive shaft, could be a bad carrier bearing as well.
Old Jan 9, 2010 | 06:24 PM
bubba3m's Avatar
X2 what he said!! ^^^^^^^^^^^
Old Jan 26, 2010 | 06:41 PM
w-dmax's Avatar
always check tie rod end oems are week
doublehbar
13
Aug 9, 2015 12:35 AM
JSATCT860
Towing and Hauling
Jun 15, 2015 11:21 PM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
