1995 dodge won't go into 4 wd
Old Jan 1, 2010 | 12:50 PM
sparky171's Avatar
Default 1995 dodge won't go into 4 wd
My 1995 dodge 2500 wont go into 4wd cheched trasfer fluid its full and clean, linkage is moving ok shift to low range can feel difference in power but still no 4wd
Old Jan 1, 2010 | 12:54 PM
12vcummins96's Avatar
check your hubs are the autoloc or manual
Old Jan 1, 2010 | 01:18 PM
sparky171's Avatar
hubs are auto no 4wd light either
Old Jan 1, 2010 | 04:18 PM
jasonfriedlin's Avatar
Arent they vacuum operated. Probably a vacuum leak or the actuator is bad. My buudy had that problem with his
Old Jan 1, 2010 | 07:53 PM
sparky171's Avatar
were would I FIND THE ACTUATOR THANKS
Old Jan 1, 2010 | 07:55 PM
casper83's Avatar
just fixed mine that had the same problem trace your vaccuum lines from the axle back, they should change to metal on the frame, and change back to plastic to go to the transfer case, what had happened to mine was the bolt used to hold the metal lines to the frame was missing and the lines had moved up and the plastic lines had melted to the exhaust, check that out and get back cause i thought it was the CAD at first till i took the time to look and it only took about 10 minutes to fix it
Old Jan 2, 2010 | 06:26 PM
wildbill's Avatar
Updates??
Old Jan 2, 2010 | 07:52 PM
kazairl's Avatar
Show me a 94+ Dodge with manual or auto locking hubs. Show me one where there is any sort of moving mechanism that engages or disengages the hubs on a Dodge.
Old Jan 5, 2010 | 01:05 PM
wildbill's Avatar
Please update.
Old Jan 5, 2010 | 02:38 PM
sparky171's Avatar
I have not been able to find a vacum leak yet I am going to be checking again tonight Thanks
