injector pump leak
Old Dec 30, 2009 | 06:03 PM
Wayne's Avatar
Default injector pump leak
well i have been having trouble with my truck and lately i have been smelling diesel, so i opened the hood and all around my injector pump was wet with diesel. then i started it and looked and it was leaking a steady drip from under the injector pump some where. i could not see the exact spot but to me it looks like a injector line leaking. could this make my truck run bad?......thanks for reading
Old Dec 30, 2009 | 06:18 PM
wildbill's Avatar
Did you try and tighten the lines??
Old Dec 30, 2009 | 06:29 PM
Wayne's Avatar
not yet i havent had time i just found the leak about an hour ago, and its to dark to mess with it tonight.
Old Dec 30, 2009 | 06:53 PM
wildbill's Avatar
Could be coming from a few places, so it's hard to tell exactly where the leak is coming from.
Old Dec 30, 2009 | 08:50 PM
Wayne's Avatar
i will try to find out tomorrow exactly where the leak is coming from so that i can give more info
Old Jan 2, 2010 | 06:20 PM
wildbill's Avatar
Updates??
Old Jan 3, 2010 | 11:48 AM
Wayne's Avatar
i pulled everything apart yesterday and it looks like it is leaking from the number 1 injector line where it goes into the pump, i tryed to tighten it but it is still leaking.
Old Jan 3, 2010 | 12:05 PM
wildbill's Avatar
Probably needs a new copper washer or whatever seals it.
Old Jan 5, 2010 | 01:05 PM
wildbill's Avatar
Updates??
Old Jan 7, 2010 | 07:42 PM
Wayne's Avatar
sorry i have been workin alot...havent had time to get on lately, thanks for the info i will look into it, you can close this thread for now i will update when i get it fixed....or not fixed
