Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
bio diesel?
Old Dec 30, 2009 | 01:59 PM
bowtech's Avatar
Default bio diesel?
i hear it cleans out built up sludge and stuff. i was wondering if i could just get some and run it through to just clean it out then keep on with reg diesel? could i do it like 70 bio 30 reg diesel? or do you have to do some thing special to run it in your truck?
wow no one?
Old Dec 30, 2009 | 03:54 PM
12vcummins96's Avatar
you can run mix thats fine note that when you run bio any rubber lines on the truck need to be changed to a hose to handle it also you will change fuel filters a couple of time real quick
Old Dec 30, 2009 | 03:59 PM
bowtech's Avatar
im wanting to run like just a hlf tank through to clean it all out would i still need to change out the hoses?
Old Dec 30, 2009 | 04:36 PM
oldsinner111's Avatar
No it won't melt them that fast.Usally it takes 6 months burning it.
Old Dec 30, 2009 | 04:40 PM
bowtech's Avatar
so you think it is beneficial to run it a tank to clean sludge or no?
Old Dec 30, 2009 | 04:53 PM
sure your truck will run better also
Old Dec 30, 2009 | 06:19 PM
bowtech's Avatar
now i just need to finnd some and how much i need to run to clean it up? if i did 50 50 would that do it or what?
Old Dec 31, 2009 | 08:08 AM
B20 for 3 months will clean things out.B50 for 6 weeks should do it.However keep extra filters and tools at all times.Diesel slime is really bad on more than 5 year old engines.or use 1 gal. veggie oil to 10 gals diesel for 3 months.It cleans also.
Old Dec 31, 2009 | 11:55 AM
bowtech's Avatar
so if i buy the veggie oil from the store i can run that 1 gal to 10gal of diesel?
Old Dec 31, 2009 | 03:17 PM
Sure can,up to 25%.It to has the solvent action of bio,but does not eat your fuel lines,or lift pump.
