Heater Issue
Old Dec 29, 2009 | 04:35 PM
wildbill's Avatar
Default Heater Issue
Going to be $600ish to replace the $50 part. I'd do it myself, but I don't have the equipment and tools to do it. Sucks *** you have to tear the entire dash apart.
Old Dec 29, 2009 | 04:36 PM
Whit's Avatar
Site Mascot
whats wrong with the door?
Old Dec 29, 2009 | 04:54 PM
wildbill's Avatar
I set it to blow air on the floor, and it goes right to the windshield. Don't get any heat on that setting.
Old Dec 29, 2009 | 04:55 PM
Whit's Avatar
Site Mascot
you cant reach up there to diognose it??
vacumn line feeding it fine??
Old Dec 29, 2009 | 04:58 PM
wildbill's Avatar
All electric. And I'm not even sure I can get to it if they have to remove the entire dash to replace the housing.
Old Dec 29, 2009 | 05:20 PM
Begle1's Avatar
Ripping apart dashes is fun!!!
Typically the "Blend Door" is the one that directs air either through or around the heater core, the ones that determine which vents the air comes out are usually called "Mode Doors".
If it's electric, try to hotwire it first...
Old Jan 1, 2010 | 07:42 PM
wildbill's Avatar
So what am I looking at here then?? Blend door or something that doesn't require the removal of the entire dash??
Old Jan 2, 2010 | 08:04 AM
PhilipR's Avatar
There is a blend door fix on eBay for like $25. Just do a search. I have seen guys pull the entire box to replace the parts and some claim they can fix it without pulling the HVAC box...IDK.....TDR had a write up in the last issue or so on how to do the blend door fix with updated Dodge parts.
kelchy82
6.2L & 6.5L Performance
10
Nov 27, 2016 04:32 PM
Mike H
Jan 25, 2015 10:08 AM
OBSBEN
Jan 8, 2015 08:21 AM
Low_Life_Style
16
Nov 29, 2014 06:28 PM
Oct 23, 2014 08:10 AM
