o3 cummins wont start
Old Dec 26, 2009 | 09:37 AM
hjedge's Avatar
Default o3 cummins wont start
running fine parked next day would not start truck has 185000 on it replaced lift pump last year checked filter canister opened drain and bumped key plenty of fuel pumping out always had a longer crank time than normal before starting
Old Dec 26, 2009 | 04:27 PM
northlandbobcatservice's Avatar
Is it firing at all? Any smoke? What area are you in? Temp?
Old Dec 27, 2009 | 01:41 PM
hjedge's Avatar
no just spins over no smoke i am in mineral wells texas 40s
just shot a skwirt of wd-40 busted right of runs fine ????? pulled codes p-2269 p-0514 p-0480
Old Dec 27, 2009 | 02:41 PM
wildbill's Avatar
P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay)
P0514 Battery Temperature Sensor Performance / Rationality
P2269 Water in Fuel Condition
Drain the filter bowl, remove/replace filter on the cap, wipe the inside of the canister down real good, and be sure to wipe around the W.I.F sensor. Reprime the system, then see if it'll fire off like normal. If not, got a fuel injection issue (CP3, injectors, or fuel relief).
The P0514, need a new batt temp sensor, and the P0480, need a new fan clutch.
Old Dec 30, 2009 | 09:41 AM
wildbill's Avatar
Updates??
Old Jan 2, 2010 | 06:18 PM
wildbill's Avatar
Please update.
Old Jan 3, 2010 | 08:39 PM
hjedge's Avatar
the truck sat for about two weeks till i got home,the truck would turn over but was not at full speed, shot of wd40 and started ,after cleaning the batterys and recharge it would turn over like it was supposed to and would start after long crank,cleared all codes and have not returned,the battery sensor was most likey do to my daughter trying to start it and cranking the heck out of it,the water in fuel code was due to the gunk in the bottom of canister, but what i did notices is while taking the lid of canister that it had tight spots so regreased and put back on till it seated up and it is back to starting like it used to i am going to replace the lid with the one that genos sells its a little higher but with metal threads with at tap for fuel preasure
Old Jan 5, 2010 | 01:13 PM
wildbill's Avatar
Well you found and fixed the problem. I will close this down, but you can reopen and update to let us know if the new lid helped any better.
Rusher48
Jul 2, 2020 08:39 AM
mcclusk
Feb 21, 2015 09:50 PM
Rusher48
Feb 20, 2015 05:19 PM
rschriek
Jan 26, 2015 07:30 AM
Downd19
Dec 30, 2014 02:49 PM
