Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
02 Super Duty running lights wont shut off!
Old Dec 23, 2009 | 09:12 AM
racerdave's Avatar
Default 02 Super Duty running lights wont shut off!
Hi folks! I have an 02 SD 350 and the running lights wont shut off. I have to go under the hood and disconnect the battery on the drivers side to get the warning buzzer and lights off. I have checked all the fuses and even pulled the DRL fuse and they still light up. What am I missing?
Old Dec 23, 2009 | 10:32 AM
ArizonaRedneck's Avatar
check your headlight switch first could be bad and welcome to diesel bombers
Old Dec 23, 2009 | 05:50 PM
dieseltechapprentice's Avatar
i have had this problem in our shop before and i belive the corection was the headlight module / switch. good luck
Old Dec 24, 2009 | 09:32 AM
racerdave's Avatar
Does the switch go bad internally? I disconnected it, cleaned the contacts and it still does it. Where is the haedlight module located?
Old Dec 24, 2009 | 09:38 AM
wildbill's Avatar
It's the same thing as the switch. If it's one you can tear apart, you might be able to sand the contacts on the inside. More than likely welded themselves together. If not, check out the parts stores or Ford for a new switch.
Old Dec 27, 2009 | 03:01 PM
wildbill's Avatar
*Moved
Apr 27, 2015 06:10 PM
Mar 11, 2015 04:00 AM
