Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
ulsd additives or not
Old Dec 17, 2009 | 04:47 PM
wyoming's Avatar
Default ulsd additives or not
got a 08 ford the dealer i got it from told me to always use fuel additives and i have been for a year every tank was wondering it i had to to it every tank or not its getting pricy over a years worth or can i just add it when in the winter and forget about adding it all time the pick up is made for ulsd THANKS for any input on this
Old Dec 17, 2009 | 07:09 PM
wildbill's Avatar
Most important are cetane, lubricants, and water dispersents.
Old Dec 17, 2009 | 07:38 PM
12vcummins96's Avatar
well you got it covered but in your truck i wouldnt worry becuase it is designed for ulsd so if you get below freezing for a long time than a additive would benefit you
Old Dec 19, 2009 | 10:45 AM
wyoming's Avatar
thanks ne one else know what i should do run additives all the time or not???
Old Dec 19, 2009 | 12:53 PM
Tinman875's Avatar
I would recommend Power service fuel additive. It contains more ctane than the competitors and provides more lubructation. every tank is a must with this low sulphur fuel. See what most peeps dont realize is that the old fuel contained sulphur for 2 reasons. 1 is for part lubricaiton but 2 the biggest part is for water displacement. the sulphur grabs the fuel and bonds to disperse and burn it without harm. the new fuel dont have as much and that is why peeps in over the road and pass rigs are having injection problems. Power service breaks apart water on a molecular level, making it seem invisible at the injector, and replaces all lost ctane (octane in gas) then boosts it by 6. also takes the gel point down to like -40. I have taken a class on power service and actually am a distributer for it, best part is it is not overly priced like some. in this day and age that is real important. Every tank brother.
Old Dec 19, 2009 | 02:26 PM
wyoming's Avatar
thanks lucky i have been useing power service in every tank now and then i use the ford stuff from the dealer its not any more money
Josh042788
Dec 14, 2014 12:15 AM
