Leaking IP or NOT???
Old Dec 16, 2009 | 01:07 AM
InTheDogHouse's Avatar
Default Leaking IP or NOT???
Last week, when the temps here got colder than usual (low 30s) the IP (or something near the IP) started leaking fuel onto the valley pan/starter/ground. Now that the temps are back to normal (50s) it has stopped leaking.
The engine always starts and runs fine, so there's no air in the system. Also, it leaked worse after sitting for several days without running, so the leak isn't related to fuel pressure either. I'm really confused, anyone have a story?
Took some pics of the IP as best I could. Good thing to have the doghouse sometimes!
Attached Thumbnails Leaking IP or NOT???-ip1.jpg   Leaking IP or NOT???-ip2.jpg   Leaking IP or NOT???-ip3.jpg
Old Dec 16, 2009 | 01:40 AM
wildbill's Avatar
Might be a loose hose or injector line.
Old Dec 16, 2009 | 02:25 AM
2500HeavyDuty's Avatar
if he had a loose injector line his idle would be affected wouldn't it?
Old Dec 16, 2009 | 12:52 PM
Sycostang67's Avatar
If it stopped leaking when the temps warmed up, I imagine it would be one of your injector o-rings. The rubber can get hard when it's cold and not seal as well.
|WYG|SS
Apr 28, 2015 03:59 PM
bryan0702
Mar 18, 2015 05:03 PM
dieselpowa
Feb 7, 2015 10:07 PM
Stox5225
Nov 18, 2014 01:04 PM
WickedEvo
Oct 20, 2014 10:50 PM
