Cummins 6.7 fuel rail pressure
Old Dec 15, 2009 | 06:51 AM
Overseer's Avatar
Default Cummins 6.7 fuel rail pressure
Looking for some help with fuel rail pressure on a 6.7 2008 Cummins. What's it suppose to be during cranking. Im stuck in Iraq and cant get this Cummins to start.....
Thanks in advance!
Old Dec 15, 2009 | 07:23 AM
wildbill's Avatar
I believe around 3000, but don't hold me to it. What all mods have you done??
Old Dec 15, 2009 | 07:40 AM
Overseer's Avatar
Nothing been done to this truck yet....
I'm not getting anything close to 3000, maybe 10.
Old Dec 15, 2009 | 08:22 AM
insane3639's Avatar
bad lift pump?
and is their any codes?
Old Dec 15, 2009 | 08:49 AM
Whit's Avatar
Site Mascot
let me clarify....you asked for rail pressure and yes it is around 3k but that is after the injection pump so thats the pressure that feeds the injectors..................you say yer only getting 10 well thats the lift pump fuel feed to the injection pump, 10 is OK as long as it doesnt dip below 5 yer OK.........what do you have for a lift pump????
Old Dec 15, 2009 | 11:09 PM
wildbill's Avatar
He's got a bad FCA, bad injector, bad fuel relief, bad CP3. The CP3 will draw fuel on it's own.
Old Dec 19, 2009 | 01:53 AM
wildbill's Avatar
Please update.
Old Dec 24, 2009 | 08:35 PM
wildbill's Avatar
Moved this to the 6.7l section.
Old Dec 24, 2009 | 09:21 PM
Horse Power's Avatar
I was just told by my dealer that it takes 6k psi at idle for one to run.
Old Dec 27, 2009 | 06:55 PM
Overseer's Avatar
Default Solved
It was the injection pump not being able to build pressure, due to the pressure relief being faulty and bypassing back to the tank. Changed out the pressure relief and was off with no issues.
Thanks a bunch for all the support!
