Oil for my dodge
Old Dec 9, 2009 | 06:18 PM
smokincummins92's Avatar
Default Oil for my dodge
I heard that Rotella changed there fomula and took out alot of the zinc...is these true? Should i change oils??
Old Dec 9, 2009 | 06:21 PM
wildbill's Avatar
Might have to make it a CJ rated oil for the newer diesels.
Old Dec 10, 2009 | 01:04 AM
Not just Rotella - virtually all oils have changed their formulation to meet emissions standards for the newer trucks.
FYI, Amsoil still has the good stuff - CI-4 rated.
Old Dec 10, 2009 | 12:42 PM
94 12valve's Avatar
x2 Amsoil is the only oil I use in both trucks
Old Dec 10, 2009 | 01:03 PM
greasemonkey's Avatar
Same here, I only use amsoil in mine and all our shop trucks.
Old Dec 10, 2009 | 01:50 PM
we just changed the oil in my uncles truck and the Rotella bottle still says approved for CI-4
Old Dec 10, 2009 | 02:20 PM
From what I can find, there's still quite a bit of CI-4 on the shelves but production has stopped and the stores will be supplied with the new CJ-4 as the CI-4 sells out.
Old Dec 11, 2009 | 04:45 PM
Heath's Avatar
Authorized Amsoil Dealer
I've not seen any CI-4+, except ours, for a couple years. The new stuff is backward compatible so any truck can use it is required for 07 and newer with the emission components in tact. I'm suprised you're actually still seeing the old stuff on the shelf. They will all say approved for CI-4.
The lower zinc in the new formulations has a lot of people concerned but in actually, they are great oils. Shown to have just as good if not better wear protection. Just doing it with other additives besides ZDDP.
I chose to run the old stuff because we have it, but wouldn't have a problem with the new if that's all I had.
Old Dec 13, 2009 | 10:43 AM
PhilipR's Avatar
I know I have read from some of the cam grinders and valvetrain guys out there that if you are stock then the CJ stuff is fine but when you start adding aftermarket cams and higher seat pressures the CJ oil is not up to snuff and you need the CI like the Amsoil AME or put an additive in with the CJ oils.
Old Dec 13, 2009 | 09:48 PM
Thanks for all the info guys I really appreciate it
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
Dec 12, 2014 12:30 PM
Nov 3, 2014 08:10 AM
