Big Rigs & Semis Discussion of Diesels Used for Transportation of Goods
1995ish c10 caterpillar fuel problems
Old Dec 6, 2009 | 07:47 PM
wadethejuggalo's Avatar
Default 1995ish c10 caterpillar fuel problems
At my votech school im working on a c10 cat and it doesnt want to prime i've cleaned and checked all the lines replaced the fuel pump and cleaned the primer plunger and it works fine. If i prime all the lines manually and crank the motor it has a very little bit of white smoke coming out i also checked and cleaned the injectors. The motor has no problem starting with some ether but it wont run on its own fuel. Any suggestions on what to do next? i also dont know if this is the right spot for this thread.
Old Dec 6, 2009 | 08:09 PM
ArizonaRedneck's Avatar
pinch the return line completely closed if it is a hose with pair of vice grips and pump the heck out of it until it wont pump anymore then try to start it when it fires and runs remove vice grips if it aint smoking it aint fueling good luck
Old Dec 7, 2009 | 04:40 PM
alright today i got it to prime i can get fuel all the way throu the system but i put a multi meter up to the injectors and im not getting any power to them at all and i think your supposed to be getting almot 100 volts out of them. i traced the electrical wires all the way to the ecm plug and they are fine so no problems with connection. any other tips will be appericated. thanks arizona redneck!
Old Dec 10, 2009 | 04:44 PM
you figure anything out yet
Old Dec 10, 2009 | 07:07 PM
well not really im putting different injectors on it to see if that can fix it but i have good grounds and no codes. My instructor who was a mechanic for 15 years doesnt even have a clue what could be wrong
Old Dec 11, 2009 | 08:29 PM
injectors put in gonna try to start it monday
Old Dec 11, 2009 | 08:40 PM
wildbill's Avatar
If it's a no go, look at a faulty ECM.
Old Dec 12, 2009 | 11:33 AM
well it cant be the ecm i tried another oone from a bulldozer c10 and i can hook a prolink up to it and it will read the motor
Old Dec 12, 2009 | 11:43 AM
let me know on monday when you try it
Old Dec 14, 2009 | 06:47 PM
didnt get to try it yet i got the valves set and injectors set but had to help somebody get a truck ready for inspection but i will be turning it over tomorrow
