What to get adrenaline or comp?
Old Dec 6, 2009 | 08:57 AM
98dodgecummins's Avatar
Default What to get adrenaline or comp?
Hello i was wondering what i should get i found a comp and a adrenaline used for both good prices and im still wondering what to get i found a adrenaline without pulse for 350.00 bucks and then i found an edge drag comp for 400.00 bucks. i dont know what do you guys thinks is a better deal. in my situation i dont really need 180 hp that the quad gives.but what do you guys think. any advice would be appreciated. Thank you.
Old Dec 6, 2009 | 09:01 AM
12vcummins96's Avatar
get the edge
Old Dec 6, 2009 | 09:17 AM
Thats what i was thanking becuase i dont need 180 hp that the quad gives and the comp will do better with pillar gauges.
Another question on the comps do you need the boost elbow that comes with them or are they not needed.
what is the best way and cleanestway to tap the pump wire with the comp?
Last edited by 98dodgecummins; Dec 6, 2009 at 09:17 AM. Reason: Automerged Doublepost
Old Dec 6, 2009 | 09:19 AM
NCFPD's Avatar
First off what eles do you have on your truck if your going with the edge you had better come up with another 300 or so bucks for gauges witch you have to have at least you can monitor some of the stuf with the addr and then down the road you can spend another 190 get the pulse and monitor everything with it and have more options i just think iyou would like it more and it would be worth the money spent and cheaper in the long run if you dont already have gauges.
Old Dec 6, 2009 | 09:21 AM
Do you think ill need a better fuel system if i get the comp. Like an airdog or raptor.
well i already have gauges.
Last edited by 98dodgecummins; Dec 6, 2009 at 09:21 AM. Reason: Automerged Doublepost
Old Dec 6, 2009 | 09:24 AM
NCFPD's Avatar
what do you have
Old Dec 6, 2009 | 09:33 AM
cummins724's Avatar
That depends on your fuel pressure when the box is on. Don't let it drop below 5psi or you will have vp failure. I think you would be happy with either box.
Old Dec 6, 2009 | 09:38 AM
NCFPD's Avatar
yea if your runnin a stocker you had better get something eles like airdog or fass product if you dont have 600 to spend on one of the big systems like i didnt i would recomend raptor 150 thats what i got with my quad addr and it does great so far i still need a fuel press gauge but i have only been running these 2 things for like 2-3 weeks in all
Old Dec 6, 2009 | 09:40 AM
i have glowshift gauges boost, fp, and egt.
does the raptor come with lifetime warranty.
Last edited by 98dodgecummins; Dec 6, 2009 at 09:40 AM. Reason: Automerged Doublepost
Old Dec 6, 2009 | 09:41 AM
NCFPD's Avatar
How do you like those gauges i was thinking about getting some
