Ford county to cummins?
Old Dec 4, 2009 | 12:51 PM
Rx7man's Avatar
Default Ford county to cummins?
Hello, I've got a 1960's Ford county super six, which is a workhorse of a tractor, but with 70 HP from a 362inch engine, and a weight of 5 tons, it's a bit underpowered... besides the fact it leaks oil like a sieve and drinks a lot of fuel as well
I'm debating wether I should play around with a turbo on it... give it 10 PSI or so, non intercooled or look for a cummins 5.9, which is a roughly similar engine as far as external dimensions
Any thoughts?
is a poor video of a walk around
Old Dec 29, 2009 | 10:51 AM
county1184's Avatar
hi there seems a shame to mess around with the tractors original form would you consider selling the machine
Regards Willie
Old Dec 29, 2009 | 02:49 PM
oldblue05's Avatar
On tractors such as that one the engine is essentially the frame and is built into the tranny... a cummins is designed for a truck for a reason. Furthermore, a cummins motor will most likely cost more than the tractor itself is worth...
Old Jan 12, 2010 | 06:19 PM
Rx7man's Avatar
well, we aren't going to sell the thing because it does just what we need it to do, and we've already put 2G's into it in tires alone. if you need a part form it, we have a parts tractor
As for the engine being part of the frame, on these tractors it IS NOT, which would simplify the swap process. Does anyone know if the pistons are oil cooled on these engines?
Old Jan 12, 2010 | 06:34 PM
Lil Red Express's Avatar
Yes they have cooling nozzles for each piston. Find a 12v from a 94-98 and stuff it in there
Old Jan 12, 2010 | 09:52 PM
dealwithit's Avatar
what does it use for the bellhousing config? can you turn up the fuel on your IP? if you can then a turbo on the stock engine might be an idea. being its a 1960's model it might not hold up that well with one tho. if you can find a complete cummins truck for cheap for a parts supply then i say go for it.
Old Jan 13, 2010 | 04:34 PM
screaminseema's Avatar
The Cummins B series is an industrial engine used in everything from Yard locomotives to irrigation pumps. It was not designed as a truck engine. First Gen 12 valves can be had for about $1000-1400. I would venture to guess his tractor is worth more than that.
You will want to find a first gen motor that had an auto behind it because it will have the lowest power rating... I can't believe I just said that.
Old Jan 30, 2010 | 08:01 PM
Rx7man's Avatar
I might find a CT26 turbo from a toyota diesel and stuff that on the county engine at 10 psi for now and I'm sure I can find a way to turn up the fuel on the pump, it's nearly identical to the 12V pumps, as it's a bosch design as well, and if it doesn't hold up, the cummins it is..
atreefunk
For Sale
Apr 13, 2015 10:57 PM
pointb912
Jan 17, 2015 01:54 PM
Nov 4, 2014 01:30 PM
Oct 14, 2014 08:40 AM
