oil burning
Old Dec 2, 2009 | 07:34 PM
Sawman's Avatar
Question oil burning
Just got a 86 ford, the trip home was about 15 miles and the truck used a half gallon of oil. Is there something other than rings that will cause this?
Old Dec 2, 2009 | 08:44 PM
ArizonaRedneck's Avatar
has it been sitting long any visible bad leaks does it smoke bad check some of these things out first unless you got it cheap bad rings right out of the shoot would suck
Old Dec 3, 2009 | 05:51 PM
Sawman's Avatar
truck was given to me so i have nothing in it, truck does blow alot of black smoke. I was tring to fix it cheap for a work truck to keep my dodge out of the saw mill thanks for help
Old Dec 3, 2009 | 11:30 PM
Sycostang67's Avatar
Black smoke would indicate too much fuel, it would be blue if it was burning to much oil. A bad CDR can increase oil consumption.
Old Dec 4, 2009 | 05:45 PM
Sawman's Avatar
dont mean to sound dumb but what is a cdr
Old Dec 4, 2009 | 10:21 PM
A CDR is a crankcase depression regulator. It's similar to a PCV valve on a gas motor. If your truck is non-turbo, it should be located on your intake, just behind the throat. If it's turbo, it should be on your driver side valve cover. It looks like a tuna can. There will be a small hole on one side, if you can blow air(use your mouth, not a compressor) through into the little hole and it comes out the big hole, then the diaphragm is broken. If it's good, then rinse it out with some gas(not diesel) and reinstall it.
Old Dec 4, 2009 | 11:08 PM
DieselCrawler's Avatar
also they do not have exhaust valve seals from the factory. i intalled them on mine and i went from using a gallon in 3000 miles to .5 qt in 3000 miles.
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
thebarzeen
Jun 16, 2015 03:35 PM
coors_man_2005
Dec 15, 2014 10:23 AM
