Jeep Liberty Discussion of Jeep Liberty CRD Diesels
diesel liberty
Old Nov 30, 2009 | 01:40 PM
lunk's Avatar
Default diesel liberty
i haven't really done to much research yet but was wondering what was the best way to make the tranny better. And any proformance upgrades for it. its a 05 liberty crd with the five speed auto. plus any problems they have had so i can keep alook out for them.
Old Dec 5, 2009 | 05:06 PM
Randy B's Avatar
I also have a 05. The converter was a problem, too weak, there was a recall. The EGR valves clog up. There are several links to site that I will email you.
Old Dec 6, 2009 | 01:15 AM
emp1134's Avatar
Suncoast makes a converter and I think its transgo that has a shift kit for the valve body. There is also a new converter from mopar that is from the European crd's and only cost about $200.
As to the EGR valves, the cheapest way to disable it is do what it called the ORM or Off Road Mod. you just unplug the mass air flow sensor, this will keep the EGR valve from opening. I did this on mine, but I sealed the plug on the wire harness side to keep water out of it to prevent a possible short. The Jeep runs the same, maybe a little better, it does get a little better mileage this way, but you will get a Check Engine Light. I am only doing this until I can get my ecm reflashed by GDE(green diesel engineering), but that will happen after the converter so that I can run there "hot" tune with out converter shudder
Only other problem area is Crank Case vapors are just "recycled" back into the intake track, instead of just being vented into the atmosphere(damn light duty diesel emissions). The problem is oil gets pass the so called trap or separator on the valve cover and ends up in the intake, turbo, intercooler and so on. There is a cheap fix for this, its called the elephant hose mod or EHM for short.
Old Apr 30, 2010 | 06:18 AM
Russell123's Avatar
I think most of the people that use the 05 liberty crd face the converter problem i also face. so what should do to overcome the problem?
Old May 6, 2010 | 01:29 AM
emp1134's Avatar
either a euro converter or a suncoast, only two choices that I know of
Old May 6, 2010 | 02:09 AM
12vcummins96's Avatar
suncoast is the best option imo
Old Aug 9, 2010 | 07:03 PM
rebelboy08's Avatar
what are some go fast mods for these and any insight on exhaust ideas?
Old Aug 13, 2010 | 01:34 PM
Deezel Stink3r's Avatar
Get a mann & hummel provent 200 filter unit to get the oil out of the PCV hoses.
It's a very common mod in australia and europe, because egr will be clogged with soot and oil.
Check your bost and intake sensor very often. If you will find soot you have the same amount and thickness in the intake manifold.
Deleting the egr is difficult(causing an EFL), but it seems to be a must have.
Old Feb 12, 2014 | 05:43 PM
lanthony2020's Avatar
Default Sonnax
Sonnax has a line pressure booster for 49 bucks. External install takes 1 minute. ATS has two TCs starting at 800.
Just bought my 2005 Liberty Diesel.
I think I will start with the sonnax and look at a GDE tune.
Good tranny shops can help out with all of this.
The tranny really needs to be drilled out and updated quite extensively to make it bullet proof. ATS is about 3000.00 for a stump puller. They have provided several to Liberty owners according to them.
Old Feb 19, 2014 | 05:11 PM
sandhillsoilburner's Avatar
Any luck with the Sunnex line Pressure Booster? Sounds very interesting...
